This children's learning tablet was manufactured in 2013. It has a black exterior, and has a medium sized X on the back. Model number: XO-780. No factory recalls.
Why isn't my tablet turning on?
I pushed the power button and nothing happens.
Score 6
4 Comments
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
by
y is not truinng on
by
I push the power button and it doesnt come on.
by
Why my vivitar tablet wont turn on
by
Add a comment
Most Helpful Answer
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
Score 3
Add a comment
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
Vivitar XO 7 Troubleshooting
Add a comment
Add your answer
Braanah Craig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 2,114
