Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Screen blank when working in OSX but works fine under windows 8.1
MacBook Pro 13" 2011 A1278 (i5 processor)
Hi,
I have a problem with my MacBook Pro 13" I have partitioned the SSD drive with both Windows 8.1 and OS-X Yosemite. I use the option key to pick the OS I want to work in.
A few weeks ago I restarted my system at which time I could not see anything on the screen the lights on the keyboard came on as per normal and the fan was working.
I plugged in an external screen and it worked perfectly. Then I restarted again in Windows 8.1 and internal screen works, and so does external screen. But, systems internal screen will not work in OS-X. At the moment I'm using system only under Windows 8.1.
I took it to the "Genius" guys at the Apple Store they said it needs new board, and wanted $500 to fix it!
How can there be a problem with the board if it works with Windows 8.1 ???
I have a technical PC background but this issue I just don't understand. Someone out there must be able to shed some light to this issue.
Please help... Thank You
Score -1
Add a comment
1 Answer
Chosen Solution
Lets try resetting the SMC services. Follow this Apple T/N: Intel-based Macs: Resetting the System Management Controller (SMC).
Also check the systems firmware following this Apple T/N: EFI and SMC firmware updates for Intel-based Macs. Make sure it's upto date.
Let us know if this solved your problem.
Score 1
Add a comment
Add your answer
Greg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
