Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
3001 Questions View all
Error 4013, a part is free inside my phone
Hello, I've got faulty Iphone 4S (error 4013). Battery has been changed but when I opened my Iphone, I found a part free inside...very little, about 3x3mm
Does anyone can tell me where this part should be placed ?
Here is the pictures (not very good quality, sorry)
http://i.imgur.com/NhSIilY.jpg
http://i.imgur.com/JL00RKq.jpg
Thanks
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
Most Helpful Answer
Hi.
The left over part is the small black ground clip on the upper screw of the battery connector.
The picture show you where to put it :)
You can see it on step 5 in the "iPhone 4S Battery Replacement"-guide
Just slide it underneath the batteryclip
For the error 4013: Put the left over part back in right place ;)
Check the dock connector. Is it connected to the logic board correct?
If all seems fine, you could try to restore thru DFU-mode. Check this guide: http://thebigboss.org/guides-iphone-ipod...
Score 2
Add a comment
Hello,
See here, step 2 : https://www.ifixit.com/Guide/iPhone+4S+B... part 5'''
"Take notice of the position of the small black ground clip on the upper screw of the battery connector. This clip is attached only by the upper screw. When reinstalling, it must be aligned so the gold contact point will press against the back cover."
This small part has not been put back in place when the battery has been replaced
HTH
Add a comment
Thank you Alex and Georges, I was almost sure this part was came from this place.
Unfortunately error 4013 is still there. I tried to disconnect almost everything (display, digitizer etc...) but no luck, I think my Iphone is down. C'est la vie.
Add a comment
Add your answer
levenrek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 898
