MacBook losing connection to battery
My girlfriends 13" white Macbook from early 2009 recently had a bad encounter with the floor and now the computer randomly shuts off at times and the battery has to be re-inserted for it to power on again, if the charger is plugged in an x will appear over the battery indicator in the menu bar.
We've tried the computer with two different batteries and the problem remains, so it's not the battery that has gone faulty.
I'm thinking it might be the battery connector that might have gotten a bit loose but I'm not sure. Has anyone else had this happen and found a solution?
Thanks in advance!
3 Comments
Can you give us the last four digits of your serial number so we can identify which version of MacBook you have.
by Dan
Last 4 of serial is R4R1
by Andrée
2.0 GHz Core 2 Duo (P7350)
Intro Date: January 20, 2009 Disc Date: May 27, 2009
Order No: MB881LL/A Model No: A1181 (EMC 2300)
Subfamily: Early 2009 Model ID: MacBook5,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 120 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by oldturkey03
