Broken 2013 logic board, upgrade to 2014?
My logic board on my MacBook Air 13" mid 2013 is damaged from coca cola spill :/
Can I change the 2013 logic board to 2014?
Here's a listing of systems within this series: MacBookAir6,2.
As you can see there is a few Early '14 that you could swap out the logic board with. These logic boards are not cheap! You may end up being happier just buying a new system.
You still could have issues within the keyboard and trackpad from the spill. So think this through carefully.
It works! Washed it with isopropanol :) Everything works!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 283
8 Comments
Please give us the last four figures of your serial number (located on the back in very fine print), so we know your exact machine.
by mayer
Or maybe I can downgrade to 2012? Cheaper...
by Mike
Will mid2013 1,4ghz fit into this? I have mid2013 1,3ghz.
by Mike
Cleaned all parts.
Well, now it starts... but stops again... will do the cleaning again.
https://www.youtube.com/watch?v=_hSYSUqT...
by Mike
I can't speak for this specific Air. Some of the older ones had issues with using a different revision of the same LCD with the motherboard.
by ABCellars
Show 3 more comments
