Repair information and troubleshooting for the Dell Latitude E6230 business class laptop computer. This laptop has a 12.5 inch screen, and was announced in May 2012.
15 Questions View all
Laptop freezes after waking from hibernation or sleep?
for the past few days, when i wake up my computer from sleep and hibernation mode it'll freeze and the only way tp get it to work is to hold the power button.
just for your information, i recently updated some drivers but i will try to delete the new power management driver and go back to the old one
Edit: i cannot roll down battery driver for some reason
Score 43
75 Comments
Brothers , just go to
1. "Device Manager"
2. "Storage controllers"
3 . Right click on "O2Micro Integrated MMC/SD controller" and disable this driver.
Your Welcome!
by
Thanks alot brother (Y)
by
I was having the same issues with my Dell latitude 5420... But with the steps above I was able to stop it... Thanks Alot...
by
me too, same issue with Latitude E6430 and the above steps solve it. Thank u very much
by
Wow...Thank U Thank U it worked for me
by
Show 70 more comments
Add a comment
Most Helpful Answer
It's one of the card readers, just disabling it fixed the issue for me
Score 9
9 Comments:
what is the card reader?
by
thanks much bro... you made my day and I have solved the problem which bothered me almost two months ..I changed the window almost thrice times but the problem still existed till today i got ur help...thanks much...
by
1. "Device Manager"
Your Welcome!
by
Thnx bro, worked for me also
by
Thanks a lot bro i too resolved by this problem
by
Show 4 more comments
Add a comment
1. "Device Manager"
Your Welcome!
Score 3
2 Comments:
Zabihullah Xabih  thank you. In my computer I have not option “O2Micro Integrated MMC/SD controller”, but I check another similar things. In my computer (M4800) the problem is option “ ControlVault decive”. Click on it and choose “Disable”. And computer works perfectly (without freezes after waking). Thank You! You helped me to find solution! :)
by
Even I changed the OS from Windows to Ubuntu and CentOS but still I’m getting the same issue and many of the users are complaining the same thing on Dell E7490. It seems some hardware issue not OS issue If we lock (Win+L) the system It's happening Hence, we are turning of the monitor instead of it. Any solutions would be appreciated. Thanks in advance!
by
Add a comment
Same issue here (caused by the Dell O2 card reader driver A04).
Edit: the A02 revision of the above driver causes the same issue.
This issue occurs in Windows 7, 8, and 10.
I fixed it by uninstalling the Dell O2 card reader driver Rev A04 and then installing the Lenovo equivalent driver from here:
http://support.lenovo.com/gb/en/download...
This covers Dell Models
E5530
E6430
E6530
And probably any other Dell laptops with the O2 card reader driver.
Score 2
Add a comment
This is indeed an O2 Micro driver problem. Delete it from Device Manager. It will ask if you want to delete drivers, and say yes. Rescan for hardware change, and let Windows 10 install default SD card reader drivers. This will allow you to still use the SD card reader and put the laptop to sleep without issues.
Score 2
Add a comment
Reinstall OS it help me with freezing while going to sleep
Add a comment
Add your answer
V_S will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 38
All Time: 51,618
