Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
Question Closed
thermal señsor cable incompatable
I bought a seagate SSHD for my iMac. Installation was pretty easy until the last steep. The sensor cable is a square, 2 hole female plug but the seagate has a rectangular receptor with 4 pins. No way to connect the two. Is there an adaptor or should I return this SSHD for something else?
Add a comment
1 Answer
Chosen Solution
Don't panic!
Ideally, you should use the same manufacture's drive your system has WD for a WD, Seagate for a Seagate etc...
If you want to stick with the Seagate drive you'll need to swap out the sensor cable harness. In this case you'll need the Apple P/N: 922-9216.
Here's one source: Intel iMac 21.5" Hard Drive Temp Sensor
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 143
