Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
Won't Charge after keyboard replacement
I replaced the Keyboard on Macbook Pro 2011 13"
After re-assembly it will not charge. The Battery dead, the LED will not show on any charger, and it will not charge.
What could be causing this? Please please please help!
Thank you
1 Comment
check if your magsafe DCin board is well connected to the logic board socket.
by
Add a comment
1 Answer
Chosen Solution
Go over all your connections(ors) again. 99% of the time a connection that appears correct or good is not completely seated or locked down.
The other cause could be the reason you replaced the keyboard - liquid spill? - may have caused damage to the logic board or components. Go over the board with a magnifier looking for corrosion (discoloration) or burn marks/swollen components.
If this answer is acceptable please remember to return and mark it accepted.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 704
