Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Speaker won't work when using the front camera
Whenever I try to record using my front camera, there is no audio. But it works just fine when I use the back camera. Is there two different speakers/mics?
Score 3
1 Comment
I got the same problem!!
by
Add a comment
There's 3 microphones in total, when you switch modes it uses a different microphone.
You need to replace the microphone which is attached to the camera. You can find a guide on how to do this here:
iPhone 5 Front-Facing Camera and Sensor Cable Replacement
Score 1
1 Comment:
The ear speaker serves as a mic for the front facing cam? Or there is a separate mic on that flat cable that I'm not aware of?
EDITE: I took a look at it and saw the mic. I've doing this for a year and never before paid attention to this simple but important details. Thanks!
by
Add a comment
Most Helpful Answer
You need to replace the front facing camera as the mic attached to it has went faulty..
The back camera uses a different mic it's located on the power flex
Score 1
Add a comment
I have the same problem as well but when I use the front camera on a app like snapchat it works just fine I don't get it then.. Pls help
2 Comments:
Same here
by
SAME HERE it is so weird
by
Add a comment
I have the same problem. On the front camera the sound doesn't work but on the back it does .But the front camera sound works on other apps like snapchat .someone help
Add a comment
SAME HERE it's so WEIRD
Add a comment
Me too. What should I do? Before, It was working normally. I did a vid using front camera and it works. I dont know what happened because the audio is not working anymore. But it is working using different apps. Really weird.
Add a comment
Add your answer
chrisNGUYENERR will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 6,494
