Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
197 Questions View all
Question Closed
Second SSD Not recognized
This is the second Mac Mini and second cable I have tried with this, and I am stuck.
I bought a SATA connector for the Late 2014 Mac Mini to install a second SSD. Once installed, I can't format the SSD. I have removed the SSD and formatted it just fine externally, but every time I plug it into the Mac, it wants to take days to format.
Any ideas as to what is wrong?
Add a comment
1 Answer
Are you certain you are not barking up the wrong tree?
AFAIK the SSD slot is a proprietary blade connector.
If this answer is acceptable please remember to return and mark it accepted.
1 Comment:
I have the SSD Mac Mini and when doing this same procedure on another Mac Mini, it worked perfectly. I also swapped out the SSD today and still have the same issue. So to recap, I have replaced the Mac, SSD, and SATA connector all with the same result.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 351
