The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Phone not turning on, not charging
Hi everyone.
I have the Galaxy S4 I9505, and recently when i woke up in the morning i saw that my phone had not charged, and that the battery was dead. The micro usb port had been acting weird for a while, and would only accept the charger that i had at home, but now it wouldn't even accept that one. So i replaced the charging module hardware part with a new one, but it still won't charge, turn on or react to anything, even though i have a charge on the battery (with external battery charger)
Regards
Stefan
Add a comment
Have you tried another wire?
5 Comments:
another wire? you mean for charging? :) thank you for answering so quickly
by
Yeah, i'd try another wire as it sounds like you've had problems with it
by
hmm.. i'll try that, But the phone will not even turn on with a charged battery put in?
by
Have you examined the phone's battery? Is it swollen? Is it holding a charge?
With a dead battery, the phone should power up when connected to a wall charger. But may be the power bank is interfering with that process?
by
I have 2 batteries, 1 original and 1 spare.. non of them will turn on the phone, so i don't believe it to be a battery problem.. are there other options ?
by
Add a comment
There are a few troubleshooting steps for this problem listed here: Samsung Galaxy S4 Troubleshooting
Add a comment
Stefan, when you say you replaced the "charging module hardware part", do you mean the micro USB port on the phone? Or do you mean you tried a new charger? If you changed the USB port (usually done by replacing the whole board the port is mounted on) then I'm out of suggestions. If not, I would try that.
Samsung Galaxy S4 USB Board Replacement
Add a comment
Add your answer
stefansigl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 7,180
