Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
What adhesive to Fasten Frame to Shell?
The loose hinge problem turns out (in my case) to be a frame that apparently separated from the aluminum shell of the Display Assembly. Is there an adhesive that you sell, or that you recommend, to fasten it back in place, so that the "loose hinge" doesn't break the glass covering the LCD (again)?
Add a comment
1 Answer
Chosen Solution
Try this adhesive strip kit: http://www.amazon.com/MacBook-Pro-Glass-...
Score 1
Add a comment
Add your answer
allancollister will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 154
