Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Spilled water on keyboard and power switch
Keyboard hasn't worked since water spill, power button worked intermittently, now doesn't. Logic board appeared to be working fine: unit turned on and functioned properly, aside from keyboard entry.
I can function with an external keyboard if I can get the machine to turn back on or fix the power button.
Score 1
Add a comment
1 Answer
There's this thing called corrosion. It doesn't always happen fast, but it happens after moisture is introduced to metals or electronics. Corrosion has caused this and may eventually kill the box entirely.
You should look at some of the questions and answers from the tag at right to see what you're in for.
At the very least you need to replace the power button (possibly the circuitry). Not many vendors have or will sell just a power button. The standard DIY repair for a liquid spill like this is to clean the logic board and replace the top case''. (An advanced DIY project).
If you decide to DIY start by studying the guide and notes for the project (not just looking them over). Obtain the recommended tools - every job is easier when you use the proper tools.
If this answer is acceptable please remember to return and mark it.
Add a comment
Add your answer
Aron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 152
