Numerous white dots or pixels on Samsung 61" DLP TV screen?
I have a Samsung 61" DLP TV about 6yrs old. Numerous white dot or pixels on screen. Can it be repaired?
Martin, this is usually caused by a bad DLP switch. Depending on your model, it could be the DLP board or the IC itself that can be replaced. If you give us your model number, we might be able to help you out further, but yes it can be fixed.
what is the chip that needs to be replaced and where is it in the tv?
kirk tupper that depends "If you give us your model number"
I have the same issue. How much will this repair cost?
Marv that depends "If you give us your model number"
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 3,375
3 Comments
samsung 61" tv screen replacement
by Julian Roberts
A replacement panel, if it can even be found, will cost more than a new TV.
by oldturkey03
Martin I have a 61 in Samsung with white dots, model hl61a650c1f sn akwk3ckq. What parts will I need. Is this a switch or chip issue
by Mike collins
