Repair guides and support for your Samsung TV.
997 Questions View all
Numerous white dots or pixels on Samsung 61" DLP TV screen?
I have a Samsung 61" DLP TV about 6yrs old. Numerous white dot or pixels on screen. Can it be repaired?
Score 2
Comments:
samsung 61" tv screen replacement
by
A replacement panel, if it can even be found, will cost more than a new TV.
by
Martin I have a 61 in Samsung with white dots, model hl61a650c1f sn akwk3ckq. What parts will I need. Is this a switch or chip issue
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Martin, this is usually caused by a bad DLP switch. Depending on your model, it could be the DLP board or the IC itself that can be replaced. If you give us your model number, we might be able to help you out further, but yes it can be fixed.
Score 1
Comments:
what is the chip that needs to be replaced and where is it in the tv?
by
kirk tupper that depends "If you give us your model number"
by
I have the same issue. How much will this repair cost?
by
by
Marv that depends "If you give us your model number"
by
Show 1 more comment
Add a comment
Add your answer
Martin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,079
