Repair and disassembly guides for Kenmore Microwaves.
182 Questions View all
Question Closed
Why is the microwave only heating when the plate spins?
we had our microwave for 8 months then one day it just stopped heating. The problem is when the plate moves it heats,when it doesn't it doesn't heat. where can we fix this.
1 Comment
I have the same problem & would like to repair. My Model is Kenmore 911.41485 or 911.41489. It is a built in micro with oven below. Not sure which model is for which.
by
Add a comment
Chosen Solution
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. But your machine should still be covered under the manufacturer warranty.
What's your model number?
Score 1
Add a comment
I have the same problem & would like to repair. My Model is Kenmore 911.41485 or 911.41489. It is a built in micro with oven below. Not sure which model is for which. Can you share if this is possible & if so where I can get parts & how to do the repair? Thank you, Nikki
1 Comment:
Which model do you have?
Kenmore Microwave Model 911.41489890
Kenmore Oven/Microwave Combo Model 911.41489991
Kenmore Oven/Microwave Combo Model 911.41489992
Kenmore Oven/Microwave Combo Model 911.41489993
Kenmore Oven/Microwave Combo Model 911.41489994
Kenmore Oven/Microwave Combo Model 911.41489995
Kenmore Oven/Microwave Combo Model 911.41489996
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 203
