13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
new fan now spins 100% speed
Hi there I just ordered a new cooling fan and after installation it only spins at 100% speed which is kinda annoying, especially because its a blower style fan and makes alot of noise. Just wondering if there is something i could have done wrong or if the fan itself could be the issue
Add a comment
1 Answer
Chosen Solution
Missing a wire/pin, or not plugged in all the way. Probably borked fan.
Why did you replace it to begin with?
Does the laptop run slow? It could be a sensor issue.
Score 1
1 Comment:
It is a borked fan. I replaced it because the stock one was on it last leg when it spun up it would make bearing noise plus I have been kinda fixing it up alitle, pulled it apart cleaned it, reapplied thermal paste, new RAM, and went to SSD. But I did all that before I ordered the fan and everything was working like it should. And I have not experienced any slow down, and the app I downloaded to read cpu temps it reading 40-41c which is where it was before but fan speed reads 0rpm.
by
Add a comment
Add your answer
mtbskilz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 75
