1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
How to retrive data from flash storage in MBA?
Hi
I my MBA (mid 2012, 13''3', 256GB) just died the other day and I was told the logic board needs replacing which is the same price as a new one. I was wondering if there is any way to get all my stuff off the flash storage without repairing the logic board?
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
Yes, there's hope!
OWC has a case which you can put your current SSD into OWC Envoy Portable - Bus-Powered USB 3.0 SSD Enclosure.
Once you get the SSD out and mounted you should be able to copy off what is on it (backing it up just in case). I would do that before bring the system in.
You'll need to put it back though, as I'm sure when they replace your logic board they will move your SSD over.
Score 2
Add a comment
Add your answer
Tara Parkes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 81
