Are replacement batteries charged?
Hi! first time posting here. I just bought a used MBP. The battery is dead, and there may be other issues as well, but my question is, if i were to buy a replacement battery from ifixit, will it come fully charged?
I'm wondering, so that way i can see if i can at least get it to boot, before buying the charger. I'm trying to get all the parts little by little, but i dont know if i'll need to buy the charger AND battery at once
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Just request that it be fully charged for you before shipping. You can do that at this link:
https://www.ifixit.com/support
Score 1
Add a comment
Most Helpful Answer
Cant say whether or not it will come charged. I can tell you how to test it, the battery you have now and your charger. In order to do this you would need a Multimeter however. If you know anyone with one or if there is a repair shop near you you can have them quickly test your current battery and charger to see if they have power of if a current is running through it correctly. You could also pick a cheap one up if you wanted, an inexpensive one would server its purpose for this.
Does the charging light on the cord turn green or orange when plugged into the port?
Score 1
Comments:
got my charger today and started testing it out. the maglight indicator turns green when i plug it in, and when i hit the battery charge button on the side, all the lights flash 5 times and then off again. i looked it up and according to apple, its a faulty battery, so ill be ordering a new one
by
Add a comment
Add your answer
Tehpenguinking will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 117
