Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
3092 Questions View all
Grey screen on startup
Tried resetting pram, reinstalling OS X, tried various commands suggested and still getting a grey screen at startup. What could the problem be and how to fix it?? Any help greatly appreciated. Thank you.
Add a comment
1 Answer
Chosen Solution
Do you have an external display which you can hook up? How about a bootable external HD?
Using both you should new able to isolate out if the internal display or the HD (OS) is damaged.
If neither one gets you anything different you'll likely need to open the system to make a thorough inspection for damage (moisture and/or burnt components).
Score 1
Add a comment
Add your answer
Gary will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 130
