The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
How to get out offlashing box
when it start a little box in middle of screen with a ? then 2 faces
Score -1
Add a comment
1 Answer
Most Helpful Answer
You have lost your boot volume. Either the Hardware (HD) or the software (System Folder) is damaged or missing. You should be able to boot from your install or hardware test CD and repair the drive software (directory) or reinstall the OS if there's space on the drive.
Of course if you're not careful you can lose all your data with an improper OS install.
What was the last thing you did, or happened right before this behavior initiated?
If this answer is acceptable please remember to return and mark it accepted.
Score 1
Add a comment
Add your answer
dennis mitchell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
