Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Comments
Did you find a solution for this? I also have a very dark/dim screen after replacing. tried replacing the screen two times. Starting to think it is the logic board
Edit: i have another, similar question in another thread, which jessabethany answered:
"Has this phone seen water?
If not, then it sounds like you're not getting enough juice through the backlight circuit. Inspect the board near the LCD connector to see if you can find any missing components. Pull up the black sticker to get a closer look.
Edit: It sounds like your phone was fine prior to using a cheap screen. These screens often have an exposed backlight flex. Closing the phone can short the backlight to ground which will blow a backlight filter on the board. Repairable. Just need to have the filter replaced and you'll be back in business.
2 Comments
by oyvindrosmer
jessa"
by oyvindrosmer
