Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Won't Power On - Even after power supply replacement
I have swapped the power supply on this iMac with one bought from iFixit. It still will not power on. No fans move, no LEDs on the mainboard.
I have checked the input voltage to the power supply and confirmed 118v at board headers. I also measured the output of the power supply and confirmed 3.8 and 12v rails give voltage. The computer still will not power on.
Should I immediately suspect a bad mainboard, or is it possible for the power button to fail? Where is the header for the power button so I can short it manually?
Update
I found the power header and tried shorting it...still no luck
I also tried swapping RAM
Score -1
2 Comments:
Can you give us some background info on what happened. Do you have a surge suppressor or UPS? Did you get hit by lightning or have a power failure?
by
Negative on all.
User did not comment on exactly what happened at the time of the failure.
by
Add a comment
1 Answer
How does the logic board look - any burn marks or swollen components?
That the customer said nothing and the poor result of replacing a blown power supply says to me voltage overload... perhaps a lightening strike?
I'd contact the customer for some more details.
If this answer is acceptable please remember to return and mark it accepted.
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 179
