Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Why is my screen blank white?!
My Macbook suffered water damage some time ago but was repaired. All was working fine for about 3 weeks when the screen began to only show up blank and white. Now everything starts up fine and the computer is running but only showing white screen. Any ideas??
Score -1
Add a comment
1 Answer
Most Helpful Answer
Connect to an external monitor... if it looks normal your GPU is good. If it does not you have a GPU/logic board problem.
Sometimes white screens are caused by corrupt boot volumes. Try to boot from a Repair disk or partition. Try a Safe (shif) boot.
If either of those work you probably need a clean install of the OS.
If this answer is acceptable please remember to return and mark it accepted.
Score 1
Add a comment
Add your answer
Brett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 189
