2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Is my ambient light sensor broken?
Hi there,
i just recently replaced my keyboard upper case with a new one and installed my old German keyboard! After putting everything back together i noticed that the LEDs change from the lowest setting to the highest setting (and back again to the lowest) repeatedly.
Could it be a problem with the ambient light sensor or does it have anything to do with the keyboard?
I have to add that the new upper case does not exactly match the old one in terms of fittings, for example for the bluetooth antenna... Also i had to change the upper case cable, as the new cable didn't fit to the connector on the logic board!
Thanks in advance for any inputs on what could be the problem!
Florian
Add a comment
Try an SMC reset.
If this answer is acceptable please remember to return and mark it accepted.
1 Comment:
Thanks for the input, but unfortunately it didn't work!
by
Add a comment
Hi Florian,
One possible solution would be to update the software on your laptop.
Add a comment
Add your answer
Florian will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 557
