Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
Replacing HD for SSD
I'm considering replacing my HDD with a SSD, and/or swapping out my malfunctioning optical drive while I am in there with either an HDD or a SSD. But I keep seeing this comment from iFixit saying that I need to replace my hard drive with the same brand as what was originally installed. No issue if I am going with HDDs, but I don't see SSDs from Toshiba out there. Anyone know if that brand consistency matters for a SSD?
1 Comment
Please make sure we have the correct model listed here or give us the last four digits of your serial number.
by
Add a comment
1 Answer
Chosen Solution
Depending on the series you may need to add-in a replacement thermal sensor to offset the removal of the one within your HD if you swap them.
If you use the dual drive kit replacing your optical drive with a SSD then you don't need to worry.
You may want to consider swapping out your HD with a SSHD which is a hybrid drive. Both Seagate & Western Digital make 3.5" SSHD's.
Score 1
Add a comment
Add your answer
seanemac007 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 233
