Repair information and guides for the fifth generation of iPhone. Model: A1387
iPhone 4s bootloop after screen replacement
Just changed the screen and the iphone now is in bootloop with the apple logo. The logic board apparently has no problem (I checked with macro lens). I tested the lcd in another Iphone and it perfect work. This is a video with the problem https://www.youtube.com/watch?v=p-dz2SDV...
Score 1
Add a comment
Most Helpful Answer
Hi.. I tried a new battery, that's what caused the boot loop (3600mah)..
I fixed this on this phone.. Maybe entirely different cause for some one else..
I noticed a power drain last night after swapping the gutt's to a new shell.. Everything worked fine, so presumed the battery was shot.. So changed it for a high powered battery, which seemed to work fine.. Was about to call the client to say its fixed, one last test.. Boot loop!!
Any way.. After searching lots of posts like this one decided to check for shorts.. Took every thing back out, tested the board while it was unscrewed, but still in place.. It worked!
So screwed it back together testing the boot sequence with every few screws.. The very last connector.. Front facing camera flex! Boot loop.. If I unplug it while in boot loop it works fine and boots up.. So I'm just waiting for a replacement flex and preying the fault is the flex and not on the logic board.. Fingers crossed
Score 1
Add a comment
Surely you know that there isn't such a thing as a high powered battery for a iPhone!
The that so called high power battery would probably cause more damage than good.
I would just swap it out for a good proper battery and take no chances
Score 1
Add a comment
Is There anyone who can help me?
Add a comment
Apparently Not... I have the same problem - iphone 5 :(
Add a comment
Hello have you tried a new battery that would be the first thing til do
Add a comment
Add your answer
Marco Micheli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 871
