Repair information and guides for MacBook Pro models with 13" displays.
9744 Questions View all
Question Closed
MacBook Pro freezes when pressure put on bottom left corner
Hi all,
So this started happening a few months ago (it didn't happen often, but now it occurs almost daily). If I happen to apply any pressure on the bottom left corner of my Macbook, whether I'm picking it up or I happen to place my phone there, the screen freezes. It used to go black, as if going into sleep mode, and then wake up after a few seconds. Recently what's been happening is that it freezes (the screen briefly turns mixed colors) and I have to reboot. If I'm in the middle of watching something when it freezes it makes a strange clicking noise. It kind of sounds like the noise at the end of a record. After I reboot it works fine right up until the next freeze. Anyone have any ideas?
Thanks!
Add a comment
Most Helpful Answer
You've given us a generic ID so I'll give you a generic answer.
You have crushed, or crimped something in that corner with constant, or one instance overpressure.
''After selecting the proper guide, studying it and the notes {not just reading it}, purchasing the proper tools)'.' Opening the box close examination with a Mark I eyeball and magnifier may find what is being pinched, or crushed and if you can restore the area to it's original configuration, or insert a shim to stop the crushing/flexing.
You'll want to correct the problem ASAP as the constant crashing can scramble your HD to the point it may no longer boot. Re-booting a frozen computer should never become SOP... that will eventually cease to be an option.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Mine has been doing the same thing. Have you had any luck resolving the issue? Thanks
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 891
