Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Question Closed
Start and Select button replacement
So my start and select buttons cracked, no problem went and got a set from my local repair store for $5, now the problem I'm having is that when I install these new black start and select buttons, both like to get stuck down after I press them once and they don't go back up. My home button does not do this even with the replacement button. Any ideas?
Add a comment
1 Answer
Chosen Solution
I was actually just having the same problem, which is how I ended up stumbling upon your question. After a lot of frustration, I realized that the two little tabs on the rear of the button were being blocked from sliding all the way into their receptacles because a little bit of plastic had bent to block the opening. Once the openings were cleared the button worked properly again.
Hopefully this photo makes things a bit clearer: http://i.imgur.com/SuYXBe5.jpg
Just make sure there's nothing blocking the slots circled in red.
Score 2
2 Comments:
THANK YOU SO MUCH, my god this was the most frustrating thing ever and now it's fixed thanks to you! THANK YOU. :O
by
Haha, I know the feeling. I nearly drove myself mad spending hours trying to reseat the buttons over and over again before I realized this.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 3,171
