Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Question Closed
Cricket wireless/MacBook's fan high rpm
I use a Cricket wireless USB modem and when I'm connected online the rpm and temp are real high. RPM is usually over 6200 and the temp reaches 163F, is this normal? When I quit the wireless and disconnect it from the MacBook, the temp drops along with the rpm.
1 Comment:
The battery is new, about 35 charge cycles on it
by
Add a comment
1 Answer
I'm guessing that this modem is powered by USB, which would make it draw power from your MacBook. USB 2.0 can provide a maximum of 5.23V, which could be enough to raise the temperature of your computer by a fair amount.
For more control and monitoring over temperature and fan speed you should take a look at CoolBook.
Add a comment
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,139
