The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Water drops fell on it, and now it only works on power!
Hello guys, i am desperate about my iPhone.after some drops of water that i had at my ear while talking,the iPhone stopped working. when i then connected the phone at the charge i saw it booting and thought it was ok....but every time i disconnect it freezes..and forcefully shuts down. i opened it and sprayed some contacts spray all over let it dry with rice etc.. and still the same. should i remove everything and spray it thoroughly an everywhere? what could be the problem. i checked the battery and has voltage so i think it is not that
Score -1
Add a comment
1 Answer
Chosen Solution
You may have
corrosion inside, you may have shorted the battery. Look through these answers especially ones dealing with water and battery.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Add a comment
Add your answer
Theodor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 5
All Time: 1,241
