Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
No syncing or charging from pc, but charges from wall or car.
I have only one charger, the one it came with. Everything was fine until today. I can't charge from usb or even have the pc see the iPhone. Charging from wall or car charger works fine. Also won't work on co-workers cable. Co-worker's iPhone works fine on my cable. iPhone was purchased 29 days ago.
Add a comment
Chosen Solution
It sounds like a cable or connector aproblem. Try replacing the cable and see if that fixes it.
If you continue to have problems that generally means the connector in the phone is bad. You will need to replace it in order to get full functionality back.
The guide to replace the connector can be found here: iPhone 3GS Dock Connector Replacement
Score 1
1 Comment:
agreed +
by
Add a comment
Most Helpful Answer
if the iPhone is not detected after connecting to the computer, it could also be a problem with the usb port, sometimes the voltage is way to low or one of the data pins is bent.
try to connect the iPhone to a different usb port/computer
Score 2
2 Comments:
Congratulations on passing the 5,000 mark. There should be a badge for that. +
by
thanks richard - maybe you'll get a huge badge when you pass the 15000 ;-)
by
Add a comment
Add your answer
abes0alternate0ego will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,099
