Logic board issue or trackpad/battery failure?
Hi there,
A few weeks ago, I spilled a cup of tea on my MB Air 13' (mid 2011 A1369). I was stupid enough not cutting the power off immediately. Then the next thing I notice was the green light of the power charge gradually dimmed and eventually the power was off.
Overnight, I turned the laptop on again, and here come the symptoms:
1. Battery is not charged when power cable is plugged in. It indicates 65% of battery but the power is cut once I unplug the power cable.
2. Trackpad malfunctions. It behaves like the left click is constantly jammed. The keyboard and the rest of the trackpad function properly. I tried to plug in an external mouse and disable the trackpad. The issue kind of resolves if the trackpad is not touched in any means (if the trackpad is touch during login, the issue remains after login even an external mouse is used.)
Attempts tried:
1.I opened the back cover and found visible water damage on the i/o board, other parts look fine to me. So I bought a i/o board from ifixit. However, the problem remains the same after I replace the i/o board.
2. Now, I have both the battery and trackpad removed. The macbook works as usual with an external mouse.
Question:
So, my question is, is this problem caused by logic board or simply a trackpad failure plus a dead battery?
This would affect my decision on whether I will pay more to fix this laptop. If the problem can be fixed by trackpad/battery replacement, I will go ahead. If it's a logic board issue, I won't spend money on replacement.
Please let me know if there is any way to tell.
Many thanks, guys.
