WifI / Bluetooth / iSight Not Working
Hi;
After a Coffee spill I have managed to get my Macbook Pro Late 2008 Unibody A1286 running again, in fact I am typing this on it. The keyboard is kaput so I am using a USB PC Kbd. The Trackpad was playing up but since I disconnected the Built in Kbd it seems OK (phew).
Anyway since I got the Mac flashed up again using the pin short out on the Logic Board the iSight / WiFi and Bluetooth are missing (No Hardware Installed Message)
Could these items have been damaged due to the Coffee spill, the Coffee went no where near the black strip under the screen where they are connected (at least I don't think they did? But I did have immense trouble re-connecting the WifI / Bluetooth connector to the Logic Board.
If I am correct its the one located near the Optical Drive and it has some sort of small plastic piece next to it that prevents you from being able to slot it straight in, what is that annoying thing (its moves).
I will take another look at the cable and also now I think I know how to get at the other end of the cable itself I'll have a look at that too.
In the mean time any help would be great
ok i checked the connector again and after a bit of fiddling the iSight Camera kicked in and with a little more fiddling the bluetooth fired up, i cannot however get the wifi working. One of the pins on connector is a little shorter than the rest so where i was having trouble inserting it i may have been damaged? As long as the socket on the motherboard is ok are these cables available separately?
by JonnyAlpha
OK after a little more provocation with a tiny screwdriver I now have all three working (Bluetooth, iSight and WiFi) so it was the connector by the Optical Drive that was the problem!!
So all that is not functioning as far as I know is the Keyboard. I am prepared to spend £50 in the hope that I can fix it. Being an honest guy I told my Insurance Company that the damaged occurred at University and they promptly informed me that I was not covered out of the house DAMM THE SMALL PRINT!!!
by JonnyAlpha
