Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 not restoring!
Hi,
I have an Iphone 5 (A1429) that randomly went into dfu mode... I wasn't able to get out of DFU nor do a restore (itunes would hang on "waiting for device").
After charging the battery for a night (it gots charge now, checked it with voltmeter) i got it to a stage where it is dispaying the itunes logo with usb cable (recovery mode) but i can't get out of that either (tried holding home and power for 10 sec, restarts and goes back into the same recovery mode)
if i connect it to Itunes now, i get it to actually starting to restore but 10 seconds after the status bar displays on both my laptop and iphone, itunes stops with error 14. I already tried re-installing itunes, deleting old IPSW and tried other wifi/ computer. I'm desperate so pleas help, i'm willing to open up my IPhone and i'm in possession of a mac, windows and ubuntu PC.
here is the log i get (only error section):
[15:25:29.0492] Failure Description:
[15:25:29.0492] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 14
[15:25:29.0492] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle data request message)
[15:25:29.0492] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle image request)
Score 1
1 Comment
here is the full itunes llog...
http://pastebin.com/NMKaz53j
by
Add a comment
Chosen Solution
just fixed the problem by doing a restore on an apple macbook... it looks like itunes for windows is not supported as much as the one on itunes as 3 windows pc's gave me the same errror and the mac just restore without a problem
Add a comment
Change battery and try again. .
2 Comments:
Hi,
thank you for answering. In the weekend i'll swap my battery with a battery from a working iphone 5 (once I find someone who will let me use their battery :p) and post the results here...
thanks!
by
also,
my battery is giving me 4.25 volts on outer connections of the battery, is this enough you think? (i charged it 2 full nights...)
thanks!
by
Add a comment
Try entering DFU mode to solve iPhone stuck in recovery mode:
Plug your device into your computer
Turn off the device by holding the Sleep/Wake or Power button and swiping it off
Hold the power button for 3 seconds
Begin holding the Home button without releasing the Sleep/Power button for 10 seconds
Release the power button and continue holding the home button until you get a popup from iTunes that your device is recognized as being in recovery mode.
Add a comment
Add your answer
Lennert will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 4,305
