The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Washer doesn't spin, smells like something burned
It did sound like it was working but after it was done the laundry still has lots of water in them, i tried to turn the switch back to spin and it sounded like it was spinning, but the laundry still came out wet. And It smelled like something's burned??
Score 1
1 Comment
I have a top loader Samsung machine it doesn't wash or spin and has a burning rubber smell
by
Add a comment
Chosen Solution
Try these two first:
Motor Coupling
If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt
If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. This may be what you're smelling.
Score 1
2 Comments:
My washer like this filled with water, but never would agitate.. just hummed/buzzed.... and smelled warm... a repairman told me it was the transmission.. does this sound reasonable.. would rather repair than buy a new washer but the quote was $300....
by
My washer was doing the same thing, turns out the computer just needed to be reset. Unplugged the washer, waited a couple hours, plugged it back in and Presto! Works fine a again! So, everyone should try that first! Good luck! :)
by
Add a comment
I also have a Kenmore Series 90 washer. I'm having the same issue, except my washer agitates just fine... it just won't spin consistently (I say consistently because I think it does spin sometimes). If I "coax" it (meaning I start it spinning by hand), it will continue spinning. Just today I noticed a burning smell, but that's new.
Mayer... should I start with the Motor Coupling?
2 Comments:
start with the belt
by
Which belt??
by
Add a comment
My front load done all of this same stuff! BUT we had pieces of rubber(like a belt maybe)in our laundry! Would it be cheaper to just buy a new washer?! Thank you!
Add a comment
Add your answer
Summerxx will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 152
All Time: 32,449
