Will my Canadian PS3 CECH-4201B work in UK?
Bringing a CECH-4201B PS3 to UK. Is this model dual voltage? Can I simply plug this model into the wall using an adapter or do I need a step down converter? thanks.
JOHN RICHMOND, "In a similar fashion to the PS3 Slim, the power supply is designed for inputs ranging from 100V to 240V AC, making it usable across the globe." you will not need a converter. from here. It is a universal power supply. All you need is a power cord the fits the UK outlet. Hope this helps, good luck.
Thanks for the answers, this is what I suspected. How do I know the PlayStation 3 Super Slim Teardown was the same model as my CECH-4201B?
You don't:-) but Sony does maintain a universal power supply across all their platforms. If you are unsure, use this guide and check for yourself:-)
Ok, so just use a UK plug adapter and plug it in? I'll try later this week once I'm moved in.
yup, that is all it is going to take. Hope you enjoy your move:-)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 781
