Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
MagSafe Sticker / adhesive
Hi,
since my Macbook is fully disassembled I decided to clean the ports and hubs etc.
They are REALLY dirty.
I started with the MagSafe . So I disconnected the MagSafe Board from the logic board and started to rub with a Q-tip and 99% Isopropanol.
But immediately the sticker came off.
Do you know where I can find a replacement or whatever
and Q-tips are a bit too big for the USB Hub etc . Does anyone know a smaller alternative?
1 Comment:
Quick follow up on this question: Is there any danger using a mac without this plastic part?
by
Add a comment
1 Answer
AFAIK there is no source for small parts like that. (You could try to pick up a damaged unit from e-bay but you'd still be in the same place... removing and reapplying the insulator) If you can't put some spray/brush adhesive on it you could try some double sticky tape.
You could also custom cut an INSULATOR out of electricians tape.
If this answer is acceptable please remember to return and mark it.
Add a comment
Add your answer
Buco Escobar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 516
