logicboard LVDS connector broken after liquid spill
Hi All,
Im hoping that some of you could offer me some assistance. I have a Macbook Air 13" (Late 2013) that unfortunatly had a glass of water spilt over it. I couldnt open it straight away as i didnt have the correct screwdriver kit. I purchased a kit and got it opened and it didnt look too bad but at this point i hadnt tried to turn it on. I cleaned up the board and turned it on... and too my surprise it turned on and the boot tone sounded but the screen didnt turn on.
I switched it back off and had a closer inspection of the video cable, and i found that the display connector (LVDS?) is damaged and needs replacing. I am experienced with soldering SMD devices (however these pins are rather small), so dont mind trying to repair it.
Where can i get one here in the UK? i see China supplies them but in batches of 10. What is the actual name of them as they are only supplying them under Macbook Air LVDS connector.
Is there anything else i need to look at? does the power for the backlight go through this same cable?
Thanks very much for your time
5 Comments
Well ive had a better look at the Macbook and it looks as though the cable and connector are both needing replacement. Im going to have to take the long wait option on the cable, ordering from China.
Further to the LCD not working, i have booted the macbook with an external display attached and all but the battery works. Its showing;
Charge Information:
Charge Remaining (mAh): 0
Fully Charged: No
Full Charge Capacity (mAh): 6808
Health Information:
Cycle Count: 78
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 6632
Does this sound as if the battery is dead or the control circuit is dead? There is some corrosion on the battery battery plug and three pins on the logic board socket are slightly tarnished, but testing with a mutimeter shows them as having continuity. A small black chip above the battery socket has a few corrosion marks around its terminals but all sides of it show continuity (not sure what its supposed to be though).
by JayT
Also, does changing the LVDS cable require removing the aluminium bezel or just the hinge cover? thanks
by JayT
"A small black chip above the battery socket has a few corrosion marks around its terminals but all sides of it show continuity (not sure what its supposed to be though)" sounds like you have a lot going on. did you ever clean the board with isopropyl alcohol and a soft brush to remove the corrosion etc? Checked for any further damage to any components? Continuity is a great test but very unreliable since there are components that do have continuity but have failed anyways. You may need to show us those components as well.
by oldturkey03
Yes its been cleaned with IPA 99.9% IPA around the corrosion and the board looks pritty much new, however there is a few iffy bits as described above. Ive ordered a new battery and VCDS cable anyhow, but id still like to test that component as its the only one other than the known back VCDS that has any noticeable corrosion.
I will get some pictures up today of all the bits mentioned.
by JayT
finally got a picture (sorry for the delay)
http://i.imgur.com/QbJlPwr.jpg
As you can see there is a little corrosion around the terminals of the SMD's
I am still waiting for bits to come from China but hopefully they will be here within the next week or so
by JayT
