Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2946 Questions View all
Why can't I turn my phone off
why can't i turn my phone off. I have a iphone 4s. Also the phone is warm
Score 3
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Bit more info would help if you want a more accurate answer..
Was it dropped
Is the screen froze
Did something happen
Score 1
Comments:
My iPhone 4s won't turn off also. I replaced the battery (from reputable company) . Fully charged phone, reset everything (as it was previously my daughters phone). Now I cannot turn off the phone. If I hold home & power buttons until the logo appears, it will turn off and then a few seconds later the apple id reappears. The battery will charge fully, but it will also discharge quickly. If anyone has any ideas, I'd be grateful. Thank you!
by
Add a comment
Maybe there is a short in the iPhone charging port. Clean iPhone charging port very well with toothbrush and isopropyl alcohol.
Score 1
Comments:
Really..??! Is that possible ..? My iPhone was charging and I pulled the charger using my feet.. Sounds weird but I'm sleeping and to lazy to wake up then as I pulled the charger from my iPhone it suddenly off and charging sign stayed and blinking on the screen. Can't charge and I brought it to a shop and they changed the battery and now the problem is I can't switch off my phone. It only locked of its own after a second. Why ..? Any help with this..?
by
Add a comment
If you can't turn your phone off try going to settings and restarting your phone. My brother had the same problem and when he did it worked
Add a comment
Add your answer
eddie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 29
Past 30 Days: 58
All Time: 6,190
