Backlight randomly turns off on MacBook mid-2009
Hi, I have an issue with my Macbook (White, 13-inch, mid-2009, s/n 45921FT09GU) where the backlight on the LCD randomly turns off while I'm using the laptop.
I can tell the screen is still working because if I look closely in a certain light I can see the info on the screen and operate (just not very efficiently).
If I flex the screen, or move it up and down, it DOES NOT cause the backlight to flicker or come on or go off. It goes off randomly.
I've plugged in an external monitor for now, turning my laptop into a desktop.
I brought a new inverter but that has NOT solved the problem.
The next thing I think I will try is to replace the inverter cable.
Of note however: I find that if I unplug the inverter cable from the inverter, and then replug them, the backlight comes back on again for a while (a random amount of time from 1second to 5 hours or more!). Could this give me a clue as to what the problem is?
I'm hoping it is not the LCD or logic board.
Any help appreciated.
Regards
Shanon
1 Comment
2.13 GHz Core 2 Duo (P7450)
Intro Date: May 27, 2009 Disc Date: October 20, 2009
Order No: MC240LL/A Model No: A1181 (EMC 2330)
Subfamily: Mid-2009 Model ID: MacBook5,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by oldturkey03
