Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Both the power and home buttons not working after screen replacement?
I replaced the screen + LCD/digitizer on my white iPhone 5, and after both the power and home buttons aren't working! I checked all the connections and the only thing I can think of is I wanted to disconnect the battery just to be safe and I tried to remove it for some reason after I disconnected it. I broke off that little plastic tab that says "Authorized Service Provider Only". I then tried to pry off the battery in the same spot and I might have damaged the thin skinny black ribbon cable that runs alongside the right side of the battery. Thanks, I need help.
Vince
Score -1
Add a comment
Right under that long skinny black cable is componants and you have for sure knock one off them off .. You will need some1 with soldering skills I would lookup Jessabethany on this site she can do this repair
Add a comment
Does it turn on? I am assuming that by them not working you mean its not turning on? Did you plug it into a computer to see if it will turn on? If not then you probably damaged the battery cable.
Add a comment
Add your answer
Vince Parisi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 95
