Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
replacement charge connector, why is it different ie no components on
i have just brought from ebay, a replacement charge connector for iphone 4, but noticed that there are no components on the bottom, just lots of glue where as there are on the original, where the components should be, why is this or have i been ripped off
Score -1
1 Comment
Neil, we can not see what you see. Post an image with your question. Use this guide Adding images to an existing question to help you with that.
by
Add a comment
1 Answer
Most Helpful Answer
The part you need is iPhone charging port assembly. It has charging port, flex cable, lower mic and connector of the home button flex cable, all a large single part. It looks like this: [linked product missing or disabled: IF182-009]
Score 1
Add a comment
Add your answer
Neil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 53
