Model A1236 / 4 or 8 GB capacity
134 Questions View all
Why is it malfunctioning after replacing the battery?
I have replaced the battery as directed. The display lit up, with a blank screen upon powering up...but that's all. After approximately 2 minutes it beeped twice, and there were dark bands on the lower area of the LCD display. Now it just beeps every 2 minutes.
After being plugged into a charging dock for 30+ minutes the lower half of the display has alternating bands of black and dark grey, and is still beeping twice every 2 minutes.
I used a soldering iron that was not calibrated...might I have fried the pcb?
Score 1
Add a comment
1 Answer
The problem you describe is due to damage to the screen.
The beep you describe maybe that replacement battery that is not good ..
If I were you I would try to change the screen display, do not think that damage to the PCB because it lights up.
Add a comment
Add your answer
maryellenhart will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 312
