Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Dead spot on iPad Mini screen!?
Ok so I replaced my iPad mini's screen for the first time because I cracked it! When i First turned it on after the replacement it worked fine except for a small "dead spot" on the diginalizer. It was a line from left to right on the bottom of the device(Not Visible, will not recognize touch) It was so small so I didn't bother with it. A few weeks later it is about a half inch think and it is at the top of my screen now. I can't do anything without twisitng the iPad billions of time. I re-seated the diginalizer and got no results! Is there any way I can fix this because I really would like to use my screen again!
Score 2
Add a comment
i had something similar happen to me with an ipad 4 but in my case the cable was just loose, if you have already checked that, i would look closely for damaged pins, the digi connector on the iPad mini board is VERY fragile , after that i would try a new digi and try to send that one back as defective
2 Comments:
I want to send it back as defective as a last resort because I can't go the time without a screen on my iPad, it is a necessity! I'm hopping there is something I can do
by
yes--check connector--it should have even rows of gold pins on both sides. If one or more is missing, that is your problem. If not, then digitizer flex, or touch ic
by
Add a comment
The screen you installed is most likely defective and will need another
Add a comment
Add your answer
Lukario45 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,208
