Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 Questions View all
How Do I Remove my Broken Screen?
I cracked my tablet screen and I have a replacement. but I cant seem to figure out how to remove the cracked screen. To clarify only cracked the glass (I think its called the digitalizer) not the LCD. Any tips?
Score 1
Add a comment
Chosen Solution
You have the back of the tablet off, unplug everything carefully then heat the frame up (careful to not melt it) and use a safe opening tool to peel the frame off the digi.
Hope this helps!
Score 1
3 Comments:
Thanks alot! i found sombody on you tube. but i mess up the glue when i went to put the new one into the frame so now it dosent lay flat but it seems to work fine anyways.
by
Jess where did you get the replacement digitizer? And how much did it cost? Thanks! Adam
by
I got mine off of ebay for $57. seems to be working fine so far!
by
Add a comment
Be careful replacing the digitizer on the Asus T100
They do have replacements on auction sites for around $30-80 depending if its being sent from overseas.
I have had terrible luck with them though -- I think they are all faulty.
Out of the 4 I've received (two shipments a couple months apart) 1 arrived cracked, and the three others all start to show "phantom touches" like crazy not very long after install, which totally makes them useless.
btw -- it costs $130 to return them to china with tracking for a $140 refund... lol... they know what they are doing...
2 Comments:
that sucks! luckily someone warned me to check where it was coming from an make sure it was from US.
by
Did you ever find a good place to get high quality replacements for these?
by
Add a comment
can someone tell me where i can get a 10.1 transformer screen
daveg002@gmail.com taanx
Add a comment
I looked on Amazon first thin and found all supplies needed at great prices. Hope this helps. And "how to" videos on YouTube.
Add a comment
Add your answer
Jess Savage will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 13,253
