Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Question Closed
White 20" iMac: A1174 logic board physically the same as A1207?
So I've been working on a 2.0 Ghz Core Duo (T2500) iMac with a faulty ATi GPU producing artifacts on the screen and generally freezing the system. Since that stuff's soldered in, I'm going to have to replace the logic board.
I understand that there's a guide floating around this site about swapping the Core Duo CPU with a Core 2 Duo, since this model of iMac surprisingly uses a socketed CPU. That makes me curious; are the physical specifications of the board the exact same throughout the 2006 line of iMacs?
Namely, could I take a logic board from the late 2006 iMac and put it inside my early 2006 iMac chassis without a problem?
Since I have to replace the logic board anyway, I figure it would be nice to get Lion running on this old iMac at the very least.
Add a comment
1 Answer
Chosen Solution
See my answer on this here and then see if you have more questions:
Core Duo CPU upgrade to Core 2 Duo CPU?
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 883
