Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Questions View all
Question Closed
Screen goes on and off until I apply pressure to left speaker?
When I turn my MacBook Pro on the screen will go on and off until I apply pressure to the left speaker. The system is running fine and continues to work without issues. I looked inside and there are a couple of screws missing from the case so I ordered them.
Any ideas would be greatly appreciated? Many Thanks
3 Comments
hi mayer that did not fix the issue it still needs me to press on the speaker next to the tab key,to begin with ,but once it has booted up completely it seems ok ?
by
is it possible that the little pins on the mother board are not contacting the outer shell, i noticed one or two of them do not spring out like the others ?
by
Add an image to your question so we can see what you see.
by
Add a comment
Chosen Solution
You are pressing on the LDVS cable connection to the logic board. Open the machine up and reseat the connection. Use some kaptan tape to help hold it in place.
Score 1
1 Comment:
by
Add a comment
Is it possible the screws which were missing are still loose inside shorting something. Can you tell us what screws you had to replace.
Score 1
Add a comment
I have the same problem on a MBP 5,1 (late 2008). The sweat spot I have to press is right on the left of the caps lock key. I was suspecting LVDS cable too but the cable is very close to the monitor and don't go near the caps lock key.
I try to disconnect and reconnect LVDS cable but got no luck so far. I might try to remove the logic board to see on the other side.
Let me know if you find a solution for this. Thanks!
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 212
