Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2170 Questions View all
Restarts every 3 seconds (bootloop)
Hello,
So I tried to repair an iphone 4s with some sort of "bootloop". It restarts every 3 seconds... ( https://www.dropbox.com/s/djk0eclmz4ognz... ).
I changed the Dock connector, I tried a new battery and tried to restore with DFU (error 4005).
Tried Restoring IPSW with redsn0w. No luck..
Could someone help please, I am out of solutions...
Thanks
Michael
Score 1
Add a comment
I had a similar problem with a 4S when I replaced the power/proximity sensor cable. Once I had replaced the cable and reassembled everything, I turned the phone on and it would freeze at the apple logo and sometimes enter a bootloop. I started inspecting the circuit board for damage but couldn't find anything that was apparent, and then I tried unplugging the power cable/proximity sensor. With the cable unplugged, I started the phone by plugging it into a USB cable and it worked perfectly!
So I would try starting the phone in that same manner to test the different components. It is possible that a bad component other than the battery or dock connector can be the problem.
Comments:
Tried to unplug every component, still no change..
The iphone flashes the apple logo (https://www.dropbox.com/s/djk0eclmz4ognz...). Could this be a problem with the Gpu or something?
Thanks
by
Add a comment
I have a samsung galaxy tab 2 10.1 thats doing this same thing. I bought and replaced a new battery, and charging flex cable and still the bootlooping remains. Many have told me that samsung is aware of this issue and it can't be fixed if it wont do a soft or hard reset. Im at a loss. VERY frustrated.
Add a comment
Add your answer
Michael Maeter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 300
