Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Replaced my display assembly on my iPhone, now nothing works
So I shattered my iphone and needed a whole new screen assembly. I got one with new cables, home button, & camera just to be safe. I put everything back together. (I'm 99.9%) I did it right, but now the touch screen won't work. Home button works, lock button, volume, and the little ringer switch work. But the touch screen won't. I have no clue why & I need some help.
Add a comment
Chosen Solution
Try reseating and cleaning the screen connectors on the screen and logic board. If you are still having problems you should try another screen.
Score 1
1 Comment:
what could I use to clean it ???
by
Add a comment
The cables can be very sensitive ,im pretty sure its not quite seated properly .
As above take it apart and check as the digitizer is the first 1 to connect when you put it together and it really dosnt take much to disconnect while doing the other cables
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
